inttools
Next revision
Previous revision
inttools [2016/03/14 12:38]
— (current)
Line 1: Line 1:
-====== Interface Tools ======
-===== General =====
-**Pointer** - moves **[[field|Fields]]** and **[[timer|Timers]]** around **[[Interfaces]]** easily. The pointer tool can also be used to resize **[[field|Fields]]** as well.
-**Field** – places **[[field#​text_graphic|Text / Graphic Fields]]** on your **[[interfaces|Interface]]**.
-**Units Field** – places **[[field#​units|Units Fields]]** on your **[[interfaces|Interface]]**.
-**Graph Field** – places **[[field#​graph|Graph Fields]]** on your **[[interfaces|Interface]]**.
-**Transition Field** – places **[[field#​transition_single_sprite|Transition Single Sprite Fields]]** on your **[[interfaces|Interface]]**.
-**Window Field** – places **[[field#​window|Window Fields]]** on your **[[interfaces|Interface]]**.
-**Static Sprite Field** – places **[[field#​static_sprite|Static Sprite Fields]]** on your **[[interfaces|Interface]]**.
-**Camera View Field** – places **[[field#​camera_view|Camera View Fields]]** on your **[[interfaces|Interface]]**.
-**Timer/​Spawn** – used to run a script at specific intervals.
-**Play Interface** – starts testing an **[[interfaces|Interface]]**.
-**Test Interface** – starts testing an **[[interfaces|Interface]]** with the option to add additional scripting when the **[[interfaces|Interface]]** is loaded.
inttools.1457977080.txt.gz · Last modified: 2016/03/14 12:38 by Lee
