templates
templates [2016/05/18 06:09]
templates [2016/12/12 04:47] (current)
Line 26: Line 26:
 **Edit Default Actor** - opens the **[[Actor]]** window where you can modify the appearance and behavioural settings of the default **[[Actor]]** that will be placed when this Actor Template is selected. This enables certain settings like Automatic Movement and Generic AI that are normally not present for the base **[[Actor]]**. **Edit Default Actor** - opens the **[[Actor]]** window where you can modify the appearance and behavioural settings of the default **[[Actor]]** that will be placed when this Actor Template is selected. This enables certain settings like Automatic Movement and Generic AI that are normally not present for the base **[[Actor]]**.
 +**Edit Blocked** - opens a "Pick Actor Template"​ window that allows users to specify which Actor Templates will block the selected Actor Template when a collision occurs.
templates.txt ยท Last modified: 2016/12/12 04:47 by Lee
