Words with numbers
Play all sorts of non-001, forum-based games here, from complex role-playing ones, to simple counting ones.
This section is NOT for games made with 001 - please use the Games section.
Deedasmi
Words with numbers
Postby Deedasmi » Thu Mar 22, 2012 8:00 pm
Hey all, I'm wanting to start an expiramental game. I will give examples, but no way to find the answer.
Person 1 says a string of characters or words, person 2 gives a number.
This is similiar to Green Glass Doors in that it actually has an answer, but you have to figure out how to find the answer
This is a sentance.
The answer is 1845
Test 2
This answer is 498
Another example!
The answer here is 1557
Hints:
It takes a little bit of work to find the answer
Case matters!
I have not seen this game anywhere before, so if google helps you, someone stole my idea : /
I'll start. My string is
zyq3
What is the answer?
Re: Words with numbers
Postby Mr.Numbers » Fri Mar 23, 2012 5:48 pm
Care to elaborate? I don't understand one bit lol
SBG
Postby SBG » Fri Mar 23, 2012 5:57 pm
Mr.Numbers wrote:Care to elaborate? I don't understand one bit lol
Ditto lol numbers are pretty arbitrary to me when it comes to getting letters out of them, apart from which letter they are in the sequence of the alphabet.
Postby Zhuge » Fri Mar 23, 2012 7:14 pm
I was able to find the answer to "Test 2" by calculating each character's number in relation to their place in the alphabet, then alternating between multiplication and addition, then multiplying by the number of characters (or adding, if you were to keep in line with the original pattern), then adding the number of characters. So -
Test 2
20 x 5 + 19 x 20 + 2 x 6 (number of characters, including spaces) + 6 = 498
Then I tried the other examples using the same pattern, but it didn't work, so I gave up. Probably because of the case matters thing, or my entire algorithm is wrong, and I just got that one correct by a fluke. :P
Hints plz.
Deedasmi
Postby Deedasmi » Fri Mar 23, 2012 8:47 pm
Deedasmi wrote:zyq3
What is the answer?
The answer is 407. I actually figured that numbers would get it.
And zhuge, you put way too much work into it lol
It relates to computers
New string =
New String
What is the answer?
Postby Mr.Numbers » Fri Mar 23, 2012 9:50 pm
I figured it out! :D Now just give me one sec to do it :P
EDIT:
Answer is 961.
New String:
001 Rocks
EDIT: God is that time consuming lol
Deedasmi
Postby Deedasmi » Sat Mar 24, 2012 12:38 am
691
I thought you would be the first to get it :P
New string:
Numberz
@edit: Not as time consuming as Zhuge's way lol.
Postby Mr.Numbers » Sun Mar 25, 2012 3:13 am
739!
New String:
No One Else Is Playing! :[
Deedasmi
Postby Deedasmi » Sun Mar 25, 2012 1:58 pm
2126, that was long you bastard.
You can give another hint if you want.
New String:
Too long.
Not Me
Location: Well... I THINK I'm here... or maybe there...
Postby Not Me » Sun Mar 25, 2012 10:24 pm
Yes, give us a hint!
The above image is totally not a link to my website.
Return to Forum-Based Games
