Spaceship Controls / Vehicle Movement
Kraven4382
Postby Kraven4382 » Sun Mar 19, 2017 9:55 pm
Hello,
I would like to make controls for a spaceship but I would like it to fly more like a spaceship than the standard vehicle coding. Does anyone know if it's possible to set a vehicle to rotate without forward movement? Something like that would probably be sufficient.
Ideally, I would like the controls to be...
Up (Forward Thrust)
Left <---- (Rotate Ship Left) (Rotate Ship Right) ---> Right
Down (Reverse Thrust)
The ship also having inertia and continuing to move in the same direction even while rotated to a different direction when the thrust is off would also be super cool.
An example of this mechanic is used in the game "Starsector" https://www.youtube.com/watch?v=RecflKfP828
If anyone knows how to make this work and has a few minutes to share I would really appreciate it.
Thanks! Kraven
twitchcoe
Re: Spaceship Controls / Vehicle Movement
Postby twitchcoe » Mon Mar 20, 2017 2:57 am
This is absolutely possible! I am using this type of control setup in my space game, though the knowledge behind the math came from Mr. Numbers ;)
You can rotate an actor with Actor("ActorName").DirectionAngle. That can be set up using something simple like this:
Turn Left (The right control is the same, I just add +0.2 instead of -0.2)
The inertial movement is another little chunk of scripting using custom events and a Push to move the actor after some calculations, though I will have to type up something more detailed to explain that part once I am a bit more awake, but it is absolutely possible!
Kraven4382
Postby Kraven4382 » Mon Mar 20, 2017 10:36 pm
Thanks so much, I can't wait to test this out!
(updated) Works fine for what I need, thanks!
